zgeorgievg
Custom fill
Trying to distinct vision glass in my drawings.
What fill do you use in your practice.
I use this symbol but I have to do it manually which is very frustrating. Any help, advice would be appreciated.
AC25 int, Win10 64bit
1 Solution
Ricardo Lopez
Hi @zgeorgievg
Creating a custom symbol fill might seem like the most obvious solution, but it may not be so straightforward because you can't control its origin on an elevation view; that's why I recommend creating a new 2D symbolic object so you can place it wherever you want.
I'm sure there could be a more elegant way to do this, but this quick and easy method gets the job done:
  1. Draw the symbol.
  2. Select all of it.
  3. File> Libraries and Objects> Save Selection as...> Object...
  4. Name and save.
  5. Place it wherever you need.
(Watch the attached video)
Ricardo López, M. Arch.
Go to post
CosminF
what do you mean by manually? You can define it as a custom fill and recall it wherever needed.
Usually I use light shading to differentiate glass, but I’m pretty sure that’s not the proper representation convention.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Ricardo Lopez
Hi @zgeorgievg
  1. Draw the symbol.
  4. Name and save.
