2026-09-07
08:06 PM
2026-09-09
01:11 PM
Trying to distinct vision glass in my drawings.
What fill do you use in your practice.
I use this symbol but I have to do it manually which is very frustrating. Any help, advice would be appreciated.
Solved! Go to Solution.
2026-09-07 10:32 PM
Hi @zgeorgievg
Creating a custom symbol fill might seem like the most obvious solution, but it may not be so straightforward because you can't control its origin on an elevation view; that's why I recommend creating a new 2D symbolic object so you can place it wherever you want.
I'm sure there could be a more elegant way to do this, but this quick and easy method gets the job done:
(Watch the attached video)
2026-09-07 09:30 PM - edited 2026-09-07 09:31 PM
what do you mean by manually? You can define it as a custom fill and recall it wherever needed.
Usually I use light shading to differentiate glass, but I’m pretty sure that’s not the proper representation convention.
2026-09-07 10:32 PM
Hi @zgeorgievg
