2010-05-19 10:52 PM - last edited on 2023-05-17 07:43 PM by Gordana Radonic
2010-05-21 06:27 PM
2010-05-21 06:36 PM
rgarand wrote:Tried it, still doesn't change the output. Still prints two side by side identical fills as different lineweights. I tried File>print>save as pdf then printed and also published the files using the publisher as a pdf then printed, both came out bad.
One of my colleagues just mentioned to me that he has this problem only when he prints from ArchiCAD. Solution being, print to PDF, open and print from Acrobat. All the fills print fine from Acrobat!
We are all on Macs here, using Acrobat 8 Pro.
2010-05-21 06:52 PM
2010-05-21 07:20 PM
2010-05-21 07:22 PM
Michael wrote:Michael, why would the printer do this conversion? Do all printers do this?
Try saving from ArchiCAD as PDF, then from the PDF save a high res tiff. I think the printer may not handle vector images and is internally converting to raster (and not doing a good job of it).
2010-05-21 07:39 PM
2010-05-21 08:06 PM
Michael wrote:I just tried that and the fills are fine but for whatever reason it comes out extremely grainy, and the file size is huge, 2.3 MB for one sheet while PDF is 238 KB for same sheet.
Its just something that I have personally encountered. Tiff files printed much cleaner that vector PDF espically when there were grayscale fills.
2010-05-21 08:11 PM
2010-05-21 08:16 PM
Michael wrote:I don't believe I can do this with just Adobe Reader. Is this correct?
2010-05-21 08:20 PM
Erika wrote:I'm contacting them now to see if they have any ideas.
Steven, what did the manufacturer say?
