Fills Disappear when printing
We are starting to have problems in several different files where the fills only partially print or disappear when printing. It happens all all of the office printers so print drivers do not appear to be the problem. Also it is occuring in two different files. Both file are teamworked, but I have saved out a solo project from each and the problems still occur. I have deleted out all but the walls and fills from the project and still I lose the fills.
This is the file as it appears when printed to PDF
And this is the file scanned from an actual print
