Graphic Override and Renovation Conflict
Is there a way to make sure that you renovation "overrides" are taking precedence over any other graphic overrides? I have a view that is overriding all cut fills, but new objects are supposed to be overridden with a different fill under my renovation settings. The "new" fill isn't showing up though.
1 Solution
M Cochran
Maybe add a criteria for your graphic override rule that excludes items with a renovation status of new? I have done this when I wanted my graphic override to only be applied to existing elements.
Margaret Cochran - BIM Manager,Technical Designer
ARCHICAD 7-23
HP ZBook 17, Windows 10
Go to post
3 Replies 3
Marc H
I believe I read that the renovation filter by default overrides other GO rules and it is not changeable. if true, it is likely another issue and folks may need more specifics to reply with a diagnosis.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
M Cochran
ARCHICAD 7-23
Thank you Margaret, I didn't think of that. It worked!
