2018-07-2410:57 AM - last edited on 2023-05-1903:22 PM by Gordana Radonic
Graphic Override - building material
2018-07-2410:57 AM
I have encounter a problem with the graphic override, or what I would want it to do but it doesn't.
I have a composite wall with 2 skins - insulation and wall, and i would like to change the only the wall skin in section. But when i use the GO ( item type - wall , building material - wall ) it also changes the section skin of my insulation.
Do you know a GO rull that would only change one skin of a composite wall?
No, but you could change the penset of your drawing placed on layout to turn the insulation cut fill foreground pen white if you want to have a simpler presentation of this skin as a possible workaround.
Just make sure you use only that pen for insulation cut fill foreground.
