Graphic Override - building material
Hello,
I have encounter a problem with the graphic override, or what I would want it to do but it doesn't.
I have a composite wall with 2 skins - insulation and wall, and i would like to change the only the wall skin in section. But when i use the GO ( item type - wall , building material - wall ) it also changes the section skin of my insulation.
Do you know a GO rull that would only change one skin of a composite wall?
Thank you.
Erwin Edel
No, but you could change the penset of your drawing placed on layout to turn the insulation cut fill foreground pen white if you want to have a simpler presentation of this skin as a possible workaround.
Just make sure you use only that pen for insulation cut fill foreground.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
