Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Graphic Overrides - Roof line types
I am trying to set-up a "Schematic" set of graphic override rules. I have set it up with a rule to have walls, columns and roofs show with a solid cut fill and a cut line pen of 4. But when this rule is applied my roofs all show a cut line type of "sketch". I can't figure out where that "sketch" setting is coming from. If I use "No Overrides" the roof has a solid line type, which is what I want. How can I get rid of these "sketchy" lines?
0 REPLIES 0
