cs_ryl
Gridline Control
Hi All,
I'm having issue with extending gridlines - from what I can see online people have two pink dots for controlling staggering, and extension of gridline head e.g. image below:
However the one I'm using at work has only one of it:
Is it to do with some settings? I'm so confused as I can't just extend gridlines by dragging it - it just staggers instead.
Thanks in advance!
AC23 AUSTRALIA
MacBook Pro M1 2020 8GB Memory | macOS Monterey 12.3.1
1 Solution
David Maudlin
cs_ryl:
Probably, the Extension and Stagger hotspots are on top of each other. Select the Grid Line, open its settings, then go to Floor Plan > Staggering and change its value. This should reset the hotspot locations.
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
3 Replies 3
David Maudlin
cs_ryl:
David
cs_ryl
Thanks @David Maudlin ! That was it.
Great tips on adding details! Already updated mine! Cheers!
AC23 AUSTRALIA
David Maudlin
cs_ryl:
Glad to know that is the solution. Thanks for adding your signature.
David
