Friday
Hi there. Is it possible to create this type of the stair with just one stair object?
I didn't want that slab to be the separator. But when I try to draw this stair at that place it doesn't let me turn 180 degrees. Have you had this type of the case?
Solved! Go to Solution.
Friday
Stair flights can not overlap when using the stair tool.
So in the case you show, that will need to be done with 2 sets of stairs.
The good thing is if they are the same heights, you can just copy and paste.
Friday
