Tazo Kikoria
High Elevation Stairs
Hi there. Is it possible to create this type of the stair with just one stair object?
I didn't want that slab to be the separator. But when I try to draw this stair at that place it doesn't let me turn 180 degrees. Have you had this type of the case?
1 Solution
Stair flights can not overlap when using the stair tool.
So in the case you show, that will need to be done with 2 sets of stairs.
The good thing is if they are the same heights, you can just copy and paste.
Go to post
