WinstoneDesign
Hot spot not showing
Been having an issue where snapping to hot spots, even when forcing with "Q" have not worked at node locations.
I've gone through my settings and work environment to ensure that grid snapping is off to coordinates so that it's not "missing" and also ensure looked into the auto hide and time delay for hot spot to show case (currently set to 0.2s).
Hoping there is some setting that may be causing the issue that has toggled off (or on) that's limiting me from snapping to the nodes.
Thank you!
Operating system used: Mac Apple Silicon 5000
1 Reply 1
Do you mean your blue snap guides are not showing? (they are not hotspots)
If so, check the snap guides button is turned on.
