2011-01-07 07:48 AM - last edited on 2023-05-19 03:59 PM by Gordana Radonic
2013-08-12 11:37 PM
2016-10-29 01:42 AM
2017-07-26 02:24 PM
2017-07-26 05:47 PM
2017-07-26 09:18 PM
2017-07-26 11:50 PM
arqrivas wrote:And why is that? The method that I tried a year ago actually solves the issue. Not a simple workaround, but it works.
( I'm not mentioning Renovation filter, because it does not apply for the topic)
2017-07-27 12:20 AM
zoli79 wrote:I wrote that because even though you can hide or show elements in a view with the renovation filters, but the renovation filter is more than just showing or hiding elements, and the topic of this thread is live enlarged plans, and it will be a bad combination to hide or show things based on renovation filters when you are working in a project where you really need then to do what they were meant to do.arqrivas wrote:And why is that? The method that I tried a year ago actually solves the issue. Not a simple workaround, but it works.
2017-07-27 12:41 AM
a bad combination to hide or show things based on renovation filters when you are working in a project where you really need then to do what they were meant to do.Maybe so, if your project is already complicated in that sense. (It would be nice if you could have combinations of ren. filters... e.g a view to show all elements on filters C and F) But it can't be generally ruled out, because many typical projects do not exploit the filter function - especially in CD phase, when design options get narrowed down.
