ā2011-01-07
07:48 AM
ā2025-07-16
12:31 PM
Molinda Prey
ā2011-01-07 08:29 AM
ā2011-01-07 08:42 AM
ā2011-01-07 08:45 AM
ā2011-01-07 08:47 AM
ā2011-01-07 08:50 AM
ā2011-01-07 08:55 AM
ā2011-01-07 09:01 AM
ā2011-01-07 09:28 AM
ā2011-01-07 10:10 AM
Deviz wrote:This would be the best option I am sure.
It's really dumb that ArchiCAD doesn't simply allows to cut a free-form detail marker, which makes everything else around disappearing and leaves the live model to be documented.
Deviz wrote:I just use the one layer for annotation.
With your option you have the advantage that you only create 2 layers per drawings set of the same scale and the disadvantage that when you work on your model everything is on top of model parts, making the annotations difficult to type, read and edit
Deviz wrote:But donāt you have the problem with bringing the white fill above the model to mask it but below all the extra annotation.
With our option we have more layers and layer combinations to create, though when I work on the model everything looks correct and clean, avoiding possible mistakes.
Deviz wrote:That is correct.
The main cons about your option for us, which makes it not suitable, is that the detail plans are next to each other and the text would overlap. That would force us to put the annotations into a separate layers for each room/area that we need to document. Back at base one again. :/
