2005-06-27 01:11 PM - last edited on 2023-05-19 12:15 AM by Gordana Radonic
2005-06-27 07:27 PM
2005-06-27 10:50 PM
Weston wrote:My drawings in PM are in AC saved views and updated from *.PLN file.
check the display option settings for both your saved view in AC and the Display Options in PM. both affest your output
hth
wes
2005-06-28 12:19 AM
Z.Bauer wrote:Then redefine views in AC with hairlines?
The drawings will be printed as they was saved in AC.
2005-06-28 02:06 AM
2005-07-05 12:11 PM
Matthew wrote:That's what I mean!
Please correct me if I am mistaken, but AFAIK PM no longer supports printing as hairlines, regardless of the view options in AC.
Matthew wrote:Yes Matthew, you are right! And I do it so. But it also would be great to do thats all automatically. GS can just add new additional option for hairlines on screen & for output . So on screen we will see one pixel width lines & for output drawings we can choose hairline=0.1mm(or 0.08, 0.05) accordingly Plotter or Printer. This method will be more easier as always for each new drawing change PENs.
The easy fix (and superior practice) is to reset the pens in the drawing to the desired line weight. ...
