ā2021-12-17 11:56 PM - edited ā2021-12-18 12:01 AM
see attached visual. describes best what I'm looking at doing.
ā2021-12-18 12:02 AM
forgot to mention...that inset you see in the top left plan..the smaller plan..was done with 2d Fills on a worksheet but I'd like to get "that" roof drain plan to be coming from the model...not 2d linework.
ā2021-12-18 03:03 PM
I think you can adjust the cutting plan in section window for required height, this you can do if "Show Cutting Plan" is ON. Then later from 3D Window you can define new 3D Document.
Also you can try to adjust the "Floor Plan Cut Plane" to the required height for Floor Plan window, this will create the 2D plan as you expect.
ā2021-12-19 11:57 AM
3D Document settings allow you to adjust the cut plane for that specific view. More info here under 3D Document Floor Plan Projection Panel
ā2021-12-19 05:25 PM
here's the hang up. my 3D Documents "projection plan" box is not able to be clicked on?
what's happening?
What am I missing, not clicking, button not checked, box not highlighted?
thanks,
ā2021-12-19 06:11 PM
@rob2218 Did you create that 3D Document View from the 3D window or the storey floor plan? The creation method is important to the results.
ā2021-12-20 02:10 AM
from the 3D window set to "plan" view from the top.
how do I create it from the story floor plan?
And.....which one will allow me to set the "view plane" height?
ā2021-12-20 09:44 AM
You need to be in standard floor plan view, NOT the 3D Window. Right click and select "New 3D Document from Floor Plan...".
ā2021-12-20 07:08 PM
thanks....yup..you were correct. was in 3D window using "top" view and that causes the "Floor Plane" button to get greyed out. Great insight. thanks.
