How to re-size master layout
I've created a master layout with a legend and title block, however without knowing I've created it in an A1 size, and I need it to be A3 size. Is there anyway I can change the size of the master layout including my legend and title block? I can't seem to re size them all at once i.e in a group.
4 Replies 4
The master page size can be changed in the master settings dialogue (select the master in the Navigator and press the 'settings' button).
Then you can re-arrange your title block to suit.
Thanks for the reply. I have resized the master layout, however it has shrunk leaving my title block oversized. But I cant seem to resize the title block all together.
If the title block is just text and lines then you will have to manually move things around so it fits on your new page size.
If it is a view placed on the master then you will need to 'open source' and edit it there.
If the title block is an object then unless it has a parameter for different page sizes you will be stuck and will have to find a new one or create your own title block.
Select all the texts and lines you want to make bigger and use the Resize command. Make sure grouping is off.
