How to show Master ID in Zone Stamps in AC17?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2014-01-03
02:18 PM
- last edited
3 weeks ago
by
Aruzhan Ilaikova
We're working on a mixed use development in which we've modelled apartment layouts as modules and hotlinked them into a teamshare model. Each hotlink is given a master ID representing the apartment number.
Within each apartment module, we've drawn a zone to the full extents of the apartment footprint with the apartment type as the Zone Name, and left the ID blank. The intention is for this zone to be visible on an overall plan view with apartment type and apartment number shown in the zone stamp.
The problem is that the Master ID doesn't seem to show on the zone stamp. I can see the Master ID added on to the zone ID under Tags & Categories, but the zone stamp only shows the zone ID without the Master ID appended.
Can anyone help?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-01-09 12:31 AM
There's a lot of potential with this! I like the direction it's headed in.
Please let us know if/what you hear.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-01-13 09:44 AM
Link wrote:Yep, I am here
Is Marton around?![]()
The source of the problem appears to be that when we introduced this new feature the GDL side hasn't been developed.
Due to internal priorities the corresponding GDL development project has been delayed, though the documentation already had the topic about the zone features.
As a first step we will update the documentation to reflect only the available options.
Apologies for this false information in the guide.
Marton
Chief Product Officer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-01-13 09:48 AM
Marton wrote:Great! What took you so long?
Yep, I am here.
Marton wrote:You know I'd really hate to upset those documentation people, can't you go and bug the GDL programmers instead?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-01-13 10:14 AM
I will try my best to raise the priority of it.
Marton
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-01-13 11:11 AM
Marton wrote:Thanks mate - that's all we can ask!
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-02-03 02:16 AM
should the Documentation be updated to reflect? because i'm still seeing:
I assume the reason this was not finished is it is tied up in the general implementation of RW access to IFC parameters from within GDL?Note: As with other elements, the Zone ID is extended by the Master ID of the module instance it belongs to. Optionally, connect the Zone ID with its Zone Number and display it in the Zone Stamp.
ā¢ For example, a Zone with an ID of Bathroom in the source file is placed into the host file as part of a HLM with a Master ID of R213. Its Zone Number will then be R213Bathroom
This has to be in AC18 ... i'm sure you guys understand how fantastically useful this will be (e.g Labelling all sorts of IFC properties of elements). It still won't match Revits capabilities (IFC Shared Parameters + View Filters) but it will be a very good step in narrowing the gap (View Filters is one of the few things i think Revit does much better than AC .. its what the Renovation Filter
cheers,
owen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-02-05 10:25 AM
This would help us meet the requirements of our biggest contractor who is currently glancing towards Revit as a solution instead.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-21 04:53 AM
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-10-21 10:27 PM
Lumion 12.5/2023
D5 Render
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2014-11-07 05:25 PM
There is now a new GDL REQUEST syntax. It is available from AC 18 build 4020 and on.
New Master ID query (from v18 4020):
result = REQUEST("Full_ID_of_parent", "", id)
It will work with the Label, D/W Marker, and Zone Stamp.
Here is an example:
dim id[]
n = REQUEST("Full_ID_of_parent", "", id)
for i = 1 to vardim1 (id)
text2 0, 0, id
next i
** Note the value is returned in an array !
Here is a sample of how the Curtain Wall DW Label works in 19 (and how you can get it to work in 18 )
The masterID_source.png shows the GDL code snippet beside the placed and labeled element. This is from the file that will be the source hotlink:
