AC17 Solo Project Browser Blocked?
I am a new user with AC17 solo. Can I copy master layouts from another drawing when setting up a new project. Or into an existing drawing.
The Project Browser seems to be disabled.
I also have access to AC18solo, is it the same with that? Do I have to upgrade to get what seems like a basic function.
Thanks
4 Replies 4
Can you post a screenshot of this blocked Project Browser?
Are you doing this using the Organizer?
Hi, thanks for the reply. screen shot is taking ages but I saw your reply to another person with similar problem and it is because I have the solo version which used to be called Starter Edition (SE) I guess I will have to make up the master sheet each time there is a new project.
Gorazd
Not quite. You can open new empty project, generate your master layouts, layer settings and all other settings that you would like and save everything as a template and use it when starting a new project. It is the same as with full version. But in SOLO and START you can not copy masters directly frome one project to another.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
Thanks, great tip, I will definitely do that. Solved.
