Simultaneous Metric and Imperial Scale Bars
Hi Y'all,
I'm working on a set of drawings for the Historic American Buildings Survey. The Department of the Interior requires:
"A pair of scale bars, English and the corresponding metric scale, is required for each scale used on a sheet of drawings."
I can't figure out how to do this
Is it possible?
Thanks in advance for any help.
I'm wondering if I can duplicate the .pln file, convert the copy to metric, create the bar scales in there, then reference them in somehow?
Has anyone ever tried this?
Erika Epstein
You can temporarily change your project settings to metric (and/or in a separate file)
- create a view of this metric graphic scale
- Place this view onto the appropriate layout. Make sure it is set to MANUAL update and be careful not to update it when you are ready to publish.
Alternatively after creating the metric scale, explode it before placing. Then you do not have to worry about accidentally updating the view. Make one for each scale you will need.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
