2004-10-16
01:17 AM
- last edited on
2025-02-07
02:04 PM
by
Aruzhan Hamar
2004-10-16 04:07 AM
2004-10-18 10:39 PM
2004-10-19 02:32 AM
2004-10-19 03:02 AM
2004-10-19 07:38 AM
2004-10-19 06:23 PM
2004-10-19 07:03 PM
Mike wrote:Thanks, Mike. I had seen that too, and tested with it checked and unchecked, and it had no effect on linking the markers. (I couldn't remember if it had to be checked or not.)
I noticed there is a check box in the Amyuni printing preferences in the advanced options tab for "Automatic conversion to hyperlinks".
2004-10-19 08:20 PM
2004-10-21 05:37 PM
Karl wrote:It works only if you 'print' to PDF converter or publish with printing to PDF converter. In ArchiCAD 9, when you publish with option 'save as PDF', the function does not work.
When you publish/print to PDF from PM, all section and detail markers become hyperlinks (well, bookmarks) to the appropriate part of the PDF document. That's as close as it gets at the moment AFAIK.
Karl
