IE IDs while using reno filter with multiple zones
I'm looking for some insight into the logic used to fill the <zoneID> and <zonename> tags used by Interior Elevation markers.
I work on a lot of demo/reno projects for office installations and make pretty meticulous use of the Renovation filter function. Currently our standard practice is to use zones for both existing and new spaces. As a result I am frequently running into problems with interior elevation markers picking up the name/ID of demo zones instead of new construction zones. My current workaround is to simply copy then delete the to-be-demolished zones when there is an issue then paste them back after the markers update. This usually works, but it's not 100%, nor have I been able to figure out exactly what is going on there. Any additional knowledge is appreciated.
0 Replies 0
