IFS expression not returning expected result
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-10-21 05:04 AM
I have an expression:
I am intended to use in an interactive schedule (Floor plan KEY), if an element has a description entered then show that, if not shows the name, if the name is blank as well (-) then show the complex profile name, if it's not a complex profile then show the composite name etc.
What I'm getting thou is "---" apart from the complex profile.
Now I haven't finished yet so I know the composite isn't showing up, but I would have thought the names and descriptions would show up.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-28 03:38 AM
I have another query, I'm not sure my description alone will be clear enough but I think the example might be.
I want to know if you can have an IFS function that has multiple logical tests.
In the virtual model there are various elements that have 3 properties in particular that I want to display depending on their values.
I'll use phones as an example, as they are pretty standard internationally.
The 3 Properties are:
- Manufacturer (eg Apple)
- Product (eg iPhone)
- Name (eg Mobile phone)
So if an element only has the name populated I want it to read "Mobile phone"
If the element has the Manufacturer and Name I want it to read "Apple Mobile Phone"
If the element has the Product and Name I want to read "iPhone Mobile Phone"
If the element has the Manufacturer, Product and Name I want it to read "Apple iPhone Mobile Phone"
Not a perfect example but hopefully conveys the idea.
I'll fill in the gaps for commas and spaces etc.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-28 03:48 AM
Rather than using IFS functions, can you create a 4th property that joins or merges the other three properties?
That way if they are blank they will be left out.
Then use the 4th result for what you want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-28 03:53 AM - edited ‎2021-10-28 03:54 AM
Thanks Barry
Yeah, something like that might work, the values aren't truly blank as they have a "-", by default. But for the first 3 properties I could have an IF to the effect of if it's "-" show nothing [ ("") ?] but if it's populated then show the value.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-28 06:02 AM - edited ‎2021-10-28 09:07 AM
IFS ( AND ( {Property:Phases/Manufacturer} <> "", {Property:Phases/Product} <> "", {Property:Phases/Name} <> "" ), TEXTJOIN ( " ", TRUE, {Property:Phases/Manufacturer}, {Property:Phases/Product}, {Property:Phases/Name} ), AND ( {Property:Phases/Manufacturer} <> "", {Property:Phases/Name} <> "" ), TEXTJOIN ( " ", TRUE, {Property:Phases/Manufacturer}, {Property:Phases/Name} ), AND ( {Property:Phases/Product} <> "", {Property:Phases/Name} <> "" ), TEXTJOIN ( " ", TRUE, {Property:Phases/Manufacturer}, {Property:Phases/Name} ) )
The above assumes that all three custom properties are available for any element in question.
If any property is not available, the expression will fail. This is the reason that a sequence of three was used in the first question because for any element only one of the profiles would be available. Also the reason a fourth sequence combining everything would not be valid. If any of one of the three properties above would not be made available to a particular element, you would have to go to the sequence method again or just let it fail.
EDIT: Or a simpler method if this is what you had in mind???
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
