2016-09-13
09:48 PM
2023-05-17
09:18 AM
Gordana Radonic
2016-09-13 11:40 PM
rob2218 wrote:Have you tried SHIFT-Clicking on the dashed line?
holly cow...i've tried everything.
I can't seem to get "THAT" line to show me the nodes.
no matter what I do.
limited, switch to unlimited...etc...
what the heck am I doing wrong here.
another FauxPA! is why can't i simply "GET" the interior marker like an exterior elevation marker and MOVE IT...to where I want? it seems the marker is like locked into the wall or something in location? Now if that aint dumb.
2016-09-13 11:43 PM
2016-09-13 11:47 PM
2016-09-13 11:48 PM
rob2218 wrote:You are selecting the wrong line. Turn on the "Marker Range." (In the on-screen view options.) Pick the DASHED LINE.
yes....I have tried "shift-clicking" on the line.
my active function disappears when I try that.
Seriously....it shouldn't be this complicated to select a node or a line.
this object is way way messed up.
2016-09-14 12:06 AM
2016-09-14 12:08 AM
2016-09-14 12:08 AM
rob2218 wrote:If you are using a limited range, the solid line will be over the dashed line initially. Move the solid line a little closer to or farther away from the marker.
I don't seem to be getting a "dashed" line like in your graphics.
My lines, all the lines, seem to be solid.
2016-09-14 12:13 AM
rob2218 wrote:Could be easier, but I don't seem to have a problem with it. You shouldn't have to be toggling limited and unlimited. You do have this range button toggled on though, right?
it seems you need to majorly fuss with the toggling of the "limited" and "unlimted" radio button to 'sortav' get that line that has the nodes to show up.....it's inconsistent and I can't seem to get it selected properly all the time.....
don't you agreed that this object/tag is f'd up?
it shouldn't be THIS hard to move a simple node left or right along the elevational plane.....just shouldn't.
2016-09-14 12:22 AM
2016-09-14 12:54 AM
rob2218 wrote:1. is a "boundary" line, and as far as I can tell, sets many of the overall extents as well as direction of the marker.
Richard, thank you for
your patience with me.
Are you sure your middle name is not "Jobe"?
if you could enlighten me a bit on what numbers 1 thru 4 do (see attached graphics) I'd surely be indentured to you.
it's a bit cumbersome all these lines, dashed, solid, ranges, limited, unlimited
thank you.
