Scott Bulmer
Importing Publisher sets between project files
The following question is on behalf of a client:
I don't think this is possible, however, is there a way to import pre-defined Publisher Sets from a refined template into an existing PLN project. I tried using the Project Chooser button in Organizer, but the Publisher Sets buttons are greyed out. Thank you for any suggestions.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Link
I don't think there is mate. I haven't found a way to do it.
Even merging only brings in one Publishing Set, in addition to the rest of the Layout Book information. There is no XML file export like there is with Project Info, and I can't see any workaround using Project Switcher.
No word form GS yet either, but they may question how it can be done if the items to be published differ between the two projects. Maybe someone else has figured it out?
Link.
