Insert from Character Map
I often need to approximate dimensions of an existing building by using a "plus-or-minus" sign. The Dimension Text Settings permit adding "+/-" to a custom dimension. Is there any way to add the more familiar "plus-or-minus" figure from the Character Map into this custom dimension text?
11 REPLIES 11
Laura Yanoviak
Stress wrote:
I don't know how to open character Viewer on a PC.
With a PC go to Start > All Programs > Accessories > System Tools > Character Map. I've pinned it to my Start Menu for easier access.
Thank you all for your tips. As you can see, I've figured out how to insert the "±" symbol in my work, and now I'm really humming.
