Interior Elevation edit placement?
Hi
i've placed a couple of interior elevations using the staggered geometry method, now it seems i cant edit them , like if i want to extend one IE, i am only allowed to offset front and back. Do i have to delete everything and redo them using the single mode? or is there an option i have overlooked that would allow me to keep the work i've done so far and just modify it?
There are different parts of the interior elevation marker that you have to select depending on what you want to edit.
There is the marker line itself and then also the extents of the elevations.
To extend the marker, you do not select the marker line like you would for the standard elevation or section markers.
You have to select the extent and adjust the nodes of that.
Even when you place them, you do so back to front compared to a standard elevation.
You define the extent first and then the position of the marker.
So it is the extend lines that govern what the marker sees.
