Is a mesh the way to make a contour map? How?
I am a new user.
I've laid a regular sloped mesh over a contour site plan (a placed autocad dwg), then i was able to change the elevations of the points to approximate the lay of the land, but it was tedious and not to clean.
Is there an easy way to 'trace' the contour lines as mesh ridges, assigning them each their own elevation?
I cant' seem to find anyting on this in the Help files or the couple of books that I have.
Thanks.
1 Reply 1
Djordje
30 seconds in ArchicadWiki (look to upper left) yielded this:
http://www.archicadwiki.com/Mesh?highlight=%28mesh%29
You can also try the search here with Countour tracing and mesh as key words, as the techniques have been discussed extensively over the years.
Check the Tips&Tricks and Resources forums too.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
