Jog in Elevation Dimension
Is there a way to add a jog to an elevation dimension? For use when elevation dimensions are close to each other?
6 Replies 6
Erika Epstein
You can't jog the string, but you could move the dimension text and add a short arrow from it to the string as done in hand drafting days.
an option, HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I think you are talking about dimension strings. I am talking about dimensions on exterior elevations like the ones places at story levels. Thanks
David Maudlin
HAL9000:
I think Erika is referring to something like this, a line or arc could be added if needed.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Bummer - I was thinking more like the jog a grid is capable of...
Erika Epstein
I've often wished for the same ability to jog the ends of the level dimensions. Story Levels can be offset, but its all or nothing, not individual like the grids.
You can manually offset the level dimension markers and move the text of same. Depending on how cluttered it gets, a little arrow, I draw mine with the spline tool, can help maintain clarity.
Make a wish if there isn't one for this. You have my vote.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erich
Perhaps a library part such as shown below would suffice? While this is not a Story Marker that will appear automatically, it does work well when needed.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
