LABEL FLIPPED WHEN MIRRORING HOTLINK MODULES. HOW TO PREVENT IT?
My door/window labels flipped when I mirrored the modules. It makes the labels jumped out of place. How to stop it flipped?
Please see attached and help.
Thank you
5 REPLIES 5
Did you try to put these kind of information into a module ?
Is it label from the same archicad version ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
I put all the door labels in the hotlink modules. I have 10 typical units so I think it will be time saver to handle from modules. However when I placed modules in the master file and mirror, the label moved around. I am looking for a way to stop it moved. Do you have any idea why it moved?
And of course, the files must be in the same version.
Thanks
I can not reproduce the problem with the different versions of Archicad I use : 20, 21 & 22.
Perhaps it's a Archicad 19 specificity ?
Christophe - FRANCE
Hi Christophe,
I am with AC 20 now.
Is it possible if you could share with your AC 20 test file? I would like to know what's wrong with my file.
Thank you
With pleasure
I'm ready to check it !
Think to do a pla with your library into
Without them i wont be able to use it as it need
Christophe - FRANCE
