2024-07-17 06:43 AM
Has anyone figured out a workflow to label invert levels of pipes in the new 27.2 MEP?
So far I've figured out that you can only use Autotext labels but once we have a route of pipes with falls the Bottom Elevation to Project Zero parameter is the closest I can find to an invert level.
But:
1. it measures to the outside of the pipe so we would have to manipulate it to deduct wall thickness.
2. it gives the RL of the lowest point on the straight section of pipe selected. Not a spot level at an intersection or a pipe mid point.
Operating system used: Windows 11 23H2
2026-01-20 02:19 AM
Anyone figured out if we can do this with 28 or 29 yet?
Tuesday
Still need this if anyone has any ideas.
