Label Window Marker Display options
For some reason my window markers which are linked through the window ID are showing up on multiple storeys. I am wondering what can I do to fix this other than manually having to tag all my windows again?
Erika Epstein
Do you have the first story set to show as trace reference and trace reference active?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
My trace reference is not turned on. Now that I look closer it seems that its showing duplicate window tags only on the Second Floor Plan. I changed the Floor Plan Cut Pane Setting in the view settings and this has seemed to fix the issue. I've had to manually redraw some low roofs that you would see below, but at least I won't have to manually redo all my window tags.
