Layer combinations in Layouts?
hopefully a very simple question:
how do i setup 2 different layouts (or master layouts) to show or hide text as necessary?
this is my 'problem':
i have a layout with an existing floorplan (with its own pen set) and a layout with a proposed plan (with a different pen set). then i have a third layout with the existing plan overlaid with the proposed plan. i have annotated the overlaid plan with text (which is part of the layout, not the drawings). i can't find a way to show the text in one layout and have it turned off in the other 2. i must be missing a simple checkbox but i've been searching help/forums and fiddling around for most of the day!
TIA
Thomas Holm
Put the text on a worksheet (write it with the layout as Trace Reference). Save a view of the worksheet and place it on the layout where you want it to be seen.
I would still use all layers visible on the layouts and only use different layer combos save in the views placed. Having a hierarchy of layer combinations might turn things very complicated very soon!
yes, this is what i ended up doing. you're right, having layout layer combos would probably overcomplicate things! thanks for the help.
