Layout ID numbering BUG in Master Layout Settings > Setup Grid..
Layout ID numbers shown on master layout that are bigger than 99 are counting wrong in Master Layout Settings > Setup Grid. This BUG appears while Flat (1,2,3..) ID logic numbering scheme.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hello,
Thank you very much for sharing the issue!
It seems like this is a limitation of the numbering system when choosing Flat ID. I suggest using the Matric ID system instead when having such a large number of cells in the layout.
I'm very sorry for the inconvenience! Please let me know if you have any further questions.
Thank you very much for your understanding!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
