Layout Page Fill Transparency Not Working
emwatson
Hi there,
I am using Archicad 24 and have found i can no longer add a fill to a layout page that has solid background in order to cover up something from the master page. In AC21 I would often do this rather than making a new master for something like hiding a north point something similar. I found this simpler then having numerous master pages and needing to remember to update revision information on multiple master layouts.
In AC24 the elements on the master page show through whether text, lines, north point etc. I have tried sending the elements on the master page to back and then on the relevant layout page where I add a fill, bringing the fill to the front however that does not fix it. Any ideas?
AC24 Australia • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.14.3
David Maudlin
emwatson:
Select the Master Layout in the Navigator and click the Settings... button. Under Name and Size > Display Master Layout: > select Below Layout.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
emwatson
Hi David,
Thanks very much for the solution! I knew there must be a simple answer.
I have also added my profile information to my signature.
Thanks,
Emily
David Maudlin
Emily:
Thanks for posting back, and adding your signature.
