Level Dimension Rotated in different scale
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-08-02
07:38 AM
2023-05-22
11:50 PM
Gordana Radonic
2021-08-02
07:38 AM
I have a level dimension in plan view. It is rotated vertically when I change the view scale from 1:100 to 1:250.
Does anyone know what is wrong?
Thank you
Labels:
- Labels:
Dimension Tools
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-08-02 08:32 AM
2021-08-02
08:32 AM
Are you simply changing the scale in the plan window or are you choosing a different view in the view map?
If you are using a view, then check the view settings to see if it is set to 'Ignore zoom and rotation when opening this view'.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-08-02 08:51 AM
2021-08-02
08:51 AM
Hi Barry
Thanks for your reply.
I changed the scale in the View Setting Dialogue of a specific view in View Map. The level dim is rotated.
I checked what you mentioned but it’s not the one.
Still dunno why.
Thanks
Still dunno why.
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-08-02 08:59 AM
2021-08-02
08:59 AM
I thought you might be changing views.
But if you are just changing the scale I am not sure why it would rotate.
Does the same happen if you just change the scale in the plan and not the view setting?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-08-02 09:38 AM
2021-08-02
09:38 AM
Hi Barry,
It’s happening the same when I change the scale directly in plan
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-08-02 09:47 AM
2021-08-02
09:47 AM
Hi Barry,
I just figured it out what’s the problem is. I will explain in detail in the next post.
Cheers
Cheers
