Level Dimension Rotated in different scale
I have a level dimension in plan view. It is rotated vertically when I change the view scale from 1:100 to 1:250.
Does anyone know what is wrong?
Thank you
5 Replies 5
Are you simply changing the scale in the plan window or are you choosing a different view in the view map?
If you are using a view, then check the view settings to see if it is set to 'Ignore zoom and rotation when opening this view'.
Hi Barry
Thanks for your reply.
I changed the scale in the View Setting Dialogue of a specific view in View Map. The level dim is rotated.
I checked what you mentioned but it’s not the one.
Still dunno why.
Thanks
I thought you might be changing views.
But if you are just changing the scale I am not sure why it would rotate.
Does the same happen if you just change the scale in the plan and not the view setting?
Hi Barry,
It’s happening the same when I change the scale directly in plan
Hi Barry,
I just figured it out what’s the problem is. I will explain in detail in the next post.
Cheers
