Line Type Selection Bug - Archicad 26/MacOS Ventura
__archiben
Morning team,
Where do we report bugs these days? My Line Type selection area flicks around all over the shop (AC26/MacOS Ventura), but never once aligns with the actual drop-down list of Line Types to choose from. It often hangs about 50mm off to the left of the drop-down, but sometimes gets stuck to the left hand side of the screen.
I have to scrub my mouse around until the selection highlight in the drop-down list activates and then I can run up and down the list until I find the linetype I'm after...
BF
b e n f r o s t
9 REPLIES 9
This is a known issue and has been reported many times. Graphisoft are aware and it is listed as a known bug in the macOS Ventura article.
Lee Hankins
macOS Sequoia (15.1.1)
Lee, do you know of any fixes for the glitchy line bug? Using arrows is very slow and also very glitchy. I have only just uploaded Version 26. thank you Helen
Have you installed the latest Hotfix for 26? The livetype bug was fixed some time ago now.
Lee Hankins
No, will do. Only just loaded Version 26.  Thank you for your help. 🙂
jackd-fjmt
@Lee Hankins
We are finding that some people are having this issue however this happens with projects in Archicad 24 (7006). The issues are coming from computers that have MacOS 13.3 and above.
Is there a fix for this?
I doubt there will be any more updates for 24 so doubt it will ever be fixed there.
As Barry said, there most likely won’t be any updates for Archicad 24. Graphisoft only maintain the last two versions of Archicad so you will need to upgrade to Archicad 25 or 26.
Lee Hankins
As others have indicated, AC24 has problems with Ventura. I have the latest updates for both Ventura and AC24 and I can no longer quit AC without generating a stalled (beachball) condition.
I am having the same issue with AC24 and Big Sur (OSX 11.7.10).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
