eilidhizat
OS Ventura Line Issues - AC23
Hi all,
I'm running a Solo AC23 licence on my iMac and recently updated to OS Ventura. I'm having issues with line types and finding I can't change these to others in the file. I've seen that this is a known issue and downloaded the update but this only seems to be for AC26 and maybe AC25. Does any one have a solution for earlier versions as it was an expensive buy for me only a few years ago and it would be a big loss if I can't use it properly now.
Thanks!
runxel
Since there is no update for AC23 the only workaround is to use your keyboard. The arrows should work and do the trick.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
