Hi all
I'm trying to do some graphic tweaking to my archicad drawings.
I would like to outline the construction with a thick line, and draw all the other lines with a thin line.
I managed to achieve this effect in plan-view (see below)
But I can't seem to do this in section.
1. There is an artefact above the window
2. Where different materials meet, they are separated with thick lines.
Left = original
Right = how i wished the outlines would be shown
So probably it must be done (if possible at all) with another method.
Especially since sometimes I use two different floorslabs above each other (for ex. bottom = foundation slab, top = insulation and finishing).  In that case, the line separating the two slabs should also be thin.
Does anyone have a clue how to achieve this?
Thanks!
