Kinga Wolter
Dimension Tool Settings
Hello,
I have two questions regarding dimensions:
1. Is staggering elevation dimension possible somehow when markers are overlapping?
Like the Grid Tool has an auto-stagger option.
2. Is there a reason dimension markers' minimum size is 1.42 Pt? Why is Label Tool's Arrowhead can be 0.28 Pt?
Thank you!
Kinga
Kinga Wolter
Project Director / BIM Manager
Intel(R) Core(TM) i7-4770K CPU @ 3.5 GHz, 32 GB RAM
NVidia Quadro M4000 1GB, 250 GB HDD, WIN10 PRO
User since AC13
Podolsky
Ace
No, there is no option for staggering overlapped elevation dimensions. You need to change position of the marker manually. When your elevation dimensions are in the chain - you need to delete overlapped marker and place another one independent, because you cannot shift to the left or right the marker from chained dimension.
I've found that minimum size for dimension marker is 0.5 mm, when for arrow 0.1 mm. No idea, why.
