Joze Marinko
Wallhole VS Egress Dimension - Sliding Door
In Doors and Windows.libpack (int) there is Exterior Sliding Door. With this door, there is no difference between wallhole and egress dimension.
In Doors and Windows USA.libpack (USA) there is also Exterior Sliding Door USA. There is difference between wallhole and egress dimension. In the background it must be calculation without possibility to change this difference.
With both doors you can't pick a frame, but it is possible to pick Casing to make some kind of frame. But with this settings you can't change difference beetwen wallhole and egress dimension.
Any idea how to manage this?
With sliding door there must be a "rail" above door, which must be visible.
What about this?
0 Replies 0
