12LKS202512
Level Dimension does not recognize a morph or beam and displays a wrong level on the plan.
Hi I drew a slanted morph wall zigzaging down the staircase edge. The level dimension tool did not recognize the morph edge so I changed the top of cap of the morph wall from morph to beam as shown in grey and still the level dimension tool does not recognize the beam in plan. everything shows as level zer, when its not!. see images.
LKS Associate Architect, Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz 3.00 GHz, 16.0 GB, 64-bit operating system, Windows 11 Pro.
Level dimension tool only works with slabs, morphs, roofs (with cover fill?) and shells.
Try the elevation label instead.
