R30
Line issue
I have a problem when drawing a straight line whenever I write a number then press enter the line doesn’t go straight instead it goes up or diagnol. It also show negative and positive which never happened before. When I write zero it go straight, if I write another number it goes diagnol. I need help plz I tried everything
2 Replies 2
Hover your cursor on a guideline, or hold the shift key after moving in the desired direction, entering the number and pressing enter...among other methods...
Or you can type X to activate the horizontal input or Y to activate the vertical input of the tracker and then type the positive/negative number.
