Line thickness of Composite at Window Opening
Where can I control the line thickness for the diverse part of a wall composite (concrete, insulation) when cut by a window opening?
1 Solution
You can do it in composite settings (attached scrsht). In some older templets pen for window opening used to be different than the outline of the wall. The other possibility is to change the pen itself.
Go to post
2 Replies 2
Thanks kzaremba
