2008-08-20
05:39 AM
2023-05-19
10:19 PM
Gordana Radonic
2008-08-20 08:24 PM
2008-08-20 08:24 PM
2008-08-20 08:31 PM
2008-08-20 08:35 PM
2008-08-20 08:41 PM
2008-08-20 08:50 PM
2008-08-20 10:46 PM
2008-08-20 11:03 PM
Karl wrote:I'm new to using the Mark-up tool, so I can't say what would be a benefit or not. However, am I missing something, or is it not possible to assign different pens weights/colors to the Mark-up notation items? If not, that just seems bizarre.
No, you saw 'correct' behavior. Elements drawn with the markup tool will display with the markup style's pens until they are converted to normal elements. This is a 'feature'.😉
I've been frustrated with the 3D appearance of markup elements - similar kind of thing as you've run into.
Might be worth posting a wish that we have a Model View Option that permits Markup Elements to be displayed with with markup attributes or with their own attributes. Would make using markup for design alternatives much more useful.
2008-08-21 01:32 AM
LINZ wrote:No, that's the way it works... guess I didn't explain clearly the first time. You can and should assign all attributes - pens, materials, layers, etc - as normal - but the elements will display with the markup pens as long as they are markup items. Only upon conversion to 'normal' items via the markup palette will they show with the assigned pens.
2008-08-21 04:20 AM
