Lining up elevations with plans in PlotMaker
Hello,
I am trying to line up an elevation view with a plan view in PlotMaker. It seems that I can not snap to any lines within the imported view... so how can I make sure that my drawings are properly alligned on the sheet?
Any help would be greatly appreciated.
3 Replies 3
__archiben
plotmaker recognises only hotspots within placed drawings.
a few strategically placed hotspots in your archiCAD views should do the trick!
HTH
~/archiben
b e n _ f r o s t
Here's another tip:
I like to put horizontal lines across the page on the master layout in a white pen. You can use this line to snap your drawings to (using the hotspots already mentioned) and the lines won't print because they're white.
Djordje
... as do a few strategically placed hotspots in the Master layout!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
