List of Drawings
Maybe we're still stuck in the 20th century, but I'm just now working on getting an automated drawing list on our cover sheet. So, I'm using the "Sheet Index" as a base and making my own custom one (all I want is the drawing name and number). I have a couple questions/problems....
We number our cover/title sheet as T-1 and our architectural drawings as A1.1 for foundation plan, A1.2 For first floor, etc. This creates a problem. The T-1 comes up last on our drawing list. Since I want the drawings listed in order, what can/should I do???
Another problem is when we use consultants, how do we get their drawings to show on our cover sheet? We normally have them send us PDF's and add them to the printed set when we're done. If we're trying to be as automated as possible, how do you achieve this?
I am interested to know how people do their drawing lists in general. We usually have to manually type them in at the end, so anything more automated would be much welcomed.
19 Replies 19
Laura Yanoviak
Within the Fields panel of the Index Settings dialog, make sure you are listing by ID first, then by name.
Yep got that, still showing up at the end...
Laura Yanoviak
Then I'm at a loss -- perhaps it's a bug within AC12, as we're still using AC11, but (as you can see from my examples) it's working for us.
Ok I'll look into it. Maybe I just need to poke around a bit...
Thank you immensely for your time and expertise.
Link
If you structure your layout book in the same order you want them indexed (typical IME), then you should just be able to use an all-encompassing subset as criteria and you won't need to apply any sorting whatsoever.
As you can see in the image it works (in AC12 2325).
Please note that since GS won't allow us to use subsets as index fields (still!), that I have used custom text to show the different sections of the document set. Then manually entered these headings into the index. Consequently they aren't live.
Link.
Laura Yanoviak
Link wrote:
...you should just be able to use an all-encompassing subset as criteria ....
I should have made note that the primary purpose of our Layout Book is construction documentation, so we don't bother with an additional "all-encompassing" Subset, although it's a perfectly logical practice.
Ok I've tried it as suggested, and it still wants to organize things alphabetically. Any ideas???
It seems that no matter how many times I try, I cannot get it to be in the order I want...
It's because your TELLING it to sort alphabetically! See Link's screenshot - with no sorting - and your screenshot which says to sort alphabetically (the down-arrow).
Oh.. stupid me...
Thank you Karl.
