Miquel Garcia
List of plans from PlotMaker
Is there any way to export the Navigator's structure in PlotMaker in text format to obtain a schedule of drawings/plans?
If not, I really want to post a wish
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
5 Replies 5
AFAIK, no.
Definitely post that wish. While you are at it, how about adding an automatic table of contents/drawing index feature? It could be just a special form of Title Type with some new more powerful autotext.
aahatimo
i thought i had seen an option in pm3 to print folder w/ a directory. i cannot find it now. was i imagining things?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
aahatimo
i was not dreaming... there is an option, only when printing from pm3.1 publisher under viewset publishing properties: 'print set structure first". checking this box sends the set structure sheet to your default printer. but it only sends drawing names, no sheet ids. i imagine this is not very useful in its present state, especially since it can only be printed, not exported.
tim hanagan
Aussie John
You could always print to PDF ( then PDF>> PNG)
Cheers John
[/size]
aahatimo
that would work for now. text could be added in the pdf, or copy text from pdf and edit it. but we need more than another 'workaround'. but at least it is a start to a drawing directory.
additional options would be great, this should be a linked tool for us. more votes @: http://www.graphisoft.com/community/archicad-talk/viewtopic.php?t=1389 may help!
tim hanagan
