2004-04-30
10:09 AM
2023-05-30
01:53 PM
Rubia Torres
2004-05-11 07:46 PM
Michael wrote:This is strange, I don't know why it doesn't work for you. To fix the problem it sounds like you could clone the view sets as team leader and toss the old ones.Matthew wrote:I've done this and the view sets created in the solo file are still not accessible for publishing by teammates. Only the view sets I created while signed in as team leader and shared are accessible by the teammates.
For some reason it seems that your view sets are not shared. To fix this you need to sign in as team leader (I'm not sure if exclusive access is required- I had it in the file I just tested). Use the pop-up to share the view set - see attached screen shot.
